stock wieght of a gts-4 coupe?
  • stock wieght of a gts-4 coupe?
    yeah its a shot in the dark but i know the info is out there some where.
    thanks
    1430 kg according to Wiki
    TROL
      gtfo ... thanks
        wait no i think that's the weight for the GTS-4R : /
        i highly doubt a GTS-4 and a 4R weigh the same.
          mine was 3220 with gas on truck scale. 4 doors aren't much heavier then 2 doors.
          The Evil 4 Door
          Nissan Skyline GTS-4 Sedan
            I believe there is only about 100lbs or 40KG if iirc between the coupe and sedan in RWD trim (source: High Performance Imports) and I will try to scan the pages tonight as there was a lengthy article on S and the RWD R chassis including information on all trim levels for three three (S chassis and R chassis 2/4dr). I know this is not really the answer to your question but it is useful information none the less.
            Sedan Lover
            1989 HCR32 Sedan
            1990 HCR32 Sedan
              1,470 kg's according to www.skylineobsession.com
                I think these weight's are from Nissan R32 catalogue (last 2x pages) for early model Series 1 R32 (1989-1991) -
                2wd coupe (2 door) = 1260 [1280]
                2wd coupe (4 door) = 1290 [1310]
                4wd coupe (2 door) = 1390 [1400]
                4wd coupe (4 door) = 1420 [1430]
                Figure in [ ] is for automatic transmission. So I guess 1430kg was correct, but for 4wd 4 door with automatic transmission.
                  are those numbers dry weight or curb weight? Anyone know?
                    Can't translate Japanese without a translator, so can't comment on that.
