every site i can find only lists a 80mm or higher head gasket bore. my rb20 is only a 78mm bore in the block. am i ok to use the 80mm bore? or is there somewhere i can buy the 78mm? thanks!
question about head gasket
digging up old thread here, but if what skym says is right, then could you explain this 78mm HG? http://www.frsport.com/Cometic-H2549...-_p_12694.html
the tomei squishes more or something?- Adam
The seal around cylinders is thinner with that metal headgasket. Factory seal around cylinders looks frayed in comparison to metal headgasket, but factory headgasket seal is still thicker than that metal headgasket with thinner seal. Most good aftermarket headgaskets have a thick, sharp edge looking factory headgasket like seal around cylinders.Last edited by Skym; 04-21-2011, 01:25 PM.RESPONSE MONSTER
