Driving around in my car the past few days, it feels to me like the bov is releasing too soon. I installed a Stiffer spring and that seems to have helped. Just wondering @ what rpm most peoples BOV are releasing? Looking at my rpm I am at about 3700-3800RPM which seems kinda high to me, but maybe I'm wrong.
@ what rpm does your BOV release?
Originally posted by Brando13 View PostMine releases at any rpm as long as I have boost pressure. It really shouldn't release until you let off the gas @ boost
Originally posted by go_n_low88 View Posthmmmm. it actually requires me to reach at least 3500 rpm before it releases while letting off the gas. If im driving around @ 2500rpm the bov does not release. Also my boost pressure does not build till then.
Originally posted by Brando13 View PostNo pressure. No blow off. Simple as that. Need a certain amount of pressure to hear it though. If it was stick open or opening prematurely you'd be losing boost pressure in your manifold
My friend has a 02 wrx and when hes around 3000-3500rpm his bov doesnt go off its just a turbo flutter sound. But when he gives it to about 4000 and up the bov releases. Could he have a circ problem? Also he makes about 5 psi at 3000-3500rpm and the car is on strock boost.Heart rate 160, I'm goin 260, RB26 run me past you in a jiffy
My car does it with stock BOV. Flutter = compressor surge and is not good for CHRA on turbo. What has happened is the boost feed hole (quick release function of BOV) on the bottom of BOV is blocked, so it uses only vacuum from manifold at top of BOV and pressure in intake pipe to force valve open. More boost = more force in intake piping to open valve hence why it works better at higher boost levels.
I bought a Synapse BOV, like R32 GTS-T in link below to solve the problem -
But still need a few parts before I can install it, which is frustrating. I like the sound of Synapse BOV on a Skyline.RESPONSE MONSTER
Originally posted by Skym View PostMy car does it with stock BOV. Flutter = compressor surge and is not good for CHRA on turbo. What has happened is the boost feed hole (quick release function of BOV) on the bottom of BOV is blocked, so it uses only vacuum from manifold at top of BOV and press in intake pipe to force valve open. More boost = more force in intake piping to open valve hence why it works better at higher boost levels.
I am selling my 1992 Gts-t. I am the first owner of this car since it was imported from Japan, September 2008. This car was my daily driver and it has never ...
The stock recirc configuration is prone to flutter when releasing throttle at low RPMs (my car still has stock and it does it).
I just can't imagine Nissan doing a flutter recirc system that would break turbos from factory.R32 GTR FULL SERVICE MANUAL DOWNLOAD:
Both are bad for CHRA on turbo.
Here's what the worst compressor surge sounds like -
My car does it because stock BOV is modified to not leak. Boost graph on dyno graph shows no leaks (boost keeps rising up to 12psi) with a bigger turbo.RESPONSE MONSTER
Originally posted by go_n_low88 View Posthmmmm. it actually requires me to reach at least 3500 rpm before it releases while letting off the gas. If im driving around @ 2500rpm the bov does not release. Also my boost pressure does not build till then.Black 1991 GTR. Serious garage stand mantle/parts car.
