hey so i was removing the pistons and i was so shocked. my oil sprayer on cylinder closest to the front broke. it broke so easy. anyone know if i need to replace it, it still points at piston but just not angled up. or anyone know where to buy one. also i looked and theres no nut or place to get at it so how would i remove it.? please any help is appreciated. Thanks,
Help!.! Broke During Build
well, you're pointing the camera right at the bolt that holds it in, so there's one problem solved. try googling the oil sprayer, i've seen them on all kinds of sites.
now as for getting that thing off, if my memory serves me correctly you need a 10mm 12-point socket, 3/8 drive is best. i'm 99 percent sure it's a 10mm, might be an 11 though, i remember buying one of those during my build but it may have been for my SPOOL conrod bolts.
ps-definitely get a new oil sprayer. they're not that expensive and it's not worth screwing up your engine over something so trivial.I've been brushing my teeth with jack but it's resulted in terrible amounts of tooth decay.
