hey i have a gtst r32 with a biger maf and biger injecters 3in doun pipe and exost and biger intercooler and intake and a rb 25 turbo at 14 psi can i run this all well with my stock ecu or do i need nistune or what would be best to run all this
r32 with sum mods can it be tuned with stock ecu
Nistune converts stock R32 ECU, so it's like a stock ECU in R35GTR, where it can be reflashed by consult port that's located under dash on drivers side. But Nistune does it in realtime, so change figure in cell on ignition map (on laptop), engine responds straight away to the change. Nistune requires consult cable (connects laptop to car), Nistune tuning software, laptop, wideband (connects to laptop).Last edited by Skym; 10-29-2010, 04:40 AM.RESPONSE MONSTER
You best bet is probably to get a powerFC and use that. Its a lot more powerful then Nistune, and you have a spare stock ECU incase anything goes wrong.
By the time you get your ECU "Nistuned" you will have spent almost as much as a used powerFC. You dont NEED a hand commander but its nice to have one.
Also dude....:
- sum
- biger
- injecters
- doun
- exost
- yelowe
- walbero
Please for the love of god, spell properly....1991 Silver Skyline R32 GT-R - SOLD You will be sorely missed girl :'(
Originally posted by aN4rk1 View PostYou best bet is probably to get a powerFC and use that. Its a lot more powerful then Nistune, and you have a spare stock ECU incase anything goes wrong.
Also dude....:
- sum
- biger
- injecters
- doun
- exost
- yelowe
- walbero
Please for the love of god, get your sources right.
How much do you think Nistune is? Also if you tune with Power FC, your stock ECU won't be useful for when "things go wrong" as it can't run the mods he mentioned.
I think you are just running off on assumption on your thoughts on Nistune.
Johnnyjohnny, good point about the daughterboard, thanks.
Chipping stock ECU is good if your not going to modify the engine past the mods you have listed.
From what I understand, PowerFC is faster than stock R32 ECU, because it has onboard boost control (same processor speed, etc as stock R33, R34 ECU with onboard boost control, etc). R32 ECU doesn't have onboard boost control, so it doesn't need the extra processor speed, etc to run multiple things at same time. R32 ECU processor speed is faster than engine, so enough for most applications, even up to 1100hp.Last edited by Skym; 10-30-2010, 01:57 AM.RESPONSE MONSTER
