At the back of the engine I was hooking up a turbo coolant line and noticed a vacuum line just hanging. It was cracked and had fallen off. It started at the plenum and was supposed to be hooked up to what looks like a fpr on the rear of the fuel rail. Are there two. I just changed the one on the front and am wondering what this is?
2nd fuel pressure regulator?
I believe its the Fuel Pressure Damper. Dampins the pulses in fuel flow coming from the Fuel pump.
Yep, just checked Fast. Damper Assy - Fuel. Section 164Last edited by beacher1B0; 03-05-2011, 04:46 PM.
That's what I thought as well. But FPR on back of engine is a damper that cancels out the pulses that reverse direction inside fuelrail due to FPR on return part of fuel rail (front of engine) creating a pulse that reverses direction.
When running 2x pumps into a fuelrail (one on each end of fuelrail), the fuel coming together in the middle of fuel rail (where it exits) acts like a damper.
At least that's how I understand how it works from what someone told me.Last edited by Skym; 03-05-2011, 05:29 PM.RESPONSE MONSTER
Ahh, interesting. Never thought about that. I also noticed in Fast that the damper only came on RB20det after 91/08. If i interpreted it correctly.Last edited by beacher1B0; 03-05-2011, 11:25 PM.
