Gts-t Clutch **NEED HELP ASAP**
  • Gts-t Clutch **NEED HELP ASAP**
    Looking for a new clutch for my r32 gts-t (hr32/kouki) skyline.
    I went on rhdjapan and found a pretty hefty selection...with some pretty hefty price tags. Wasn't to interested in that, I checked out ebay and seen lots of f1 clutch's. Read some reviews on them, some say their good, some say their bad.
    I haven't found anything else out there I'd buy, anyone got any experience in this or know were I could get one at a decent price?
    Thanks
    -Stephen
    Originally posted by Robski
    ACT is cheap and good quality. got a 6puck plus pressure plate for under 500
    - Adam
      or if u just want like oem quality, just pick up a replacement at ur local parts store. not sure what would be an exact bolt on, but im thinking 300zx?
      - Adam
        i got a exedy one for under 500 runs its pretty amazing for dd
          exedy is good for the money. They make oem clutches for a bunch of manufacturers, so it's not like they're shoddy quality.
          1/1_Scale
          パーソナリティは、1つを得る
            300zx N/A works.
            THE TWIN TURBO 300ZX CLUTCH DOES NOT WORK. DO NOT GET IT.
            THE N/A 300ZX clutch is the exact same as the rb20/25 if you are looking for a stock replacement
            Originally posted by m_melen
              I've got a question or two about this. I found Exedy clutch discs for 300ZX online. The N/A model is the "VG30DE," correct?
              Here's where I found it, they also sell the disc individually.
              And, should I be automatically replacing something like the cover, release bearing, or pilot bearing when replacing the disc?
              Do these parts even fit from the 300ZX to the RB20DET or is it just the clutch disc?
                and have people had luck removing the pilot bearings on these using the grease method or even shredded up wet paper? or are they a bitch to get out like the timing gear tends to be...
