What would be the chances if you blew a head gasket and it over heated... Could the block crack? let me know ur thoughts.
Cracked block????????
hope that didn't happen to you. RB26 is pretty strong. but I'd go crazy with a leek test,wet test, compression test. there are some good how too videos on utube.
also if you have any buddys with those new camera's that can go in the block.1993 GTR
1992 GTS-T Type - M (Sold)
Your head is more likely to crack then block since the head is aluminum. Your HG could be perfectly okay, but you may have put a wee crack in between the water jackets and chamber.
Exactly what was wrong with my car.Heart rate 160, I'm goin 260, RB26 run me past you in a jiffy
