Where can i find Detachable steering hub
  • Where can i find Detachable steering hub
    As the title states im looking for a removable hub for a gts-t
    Thanks guys
    92,94,95 Honda Civic
    92,92,93 Nissan Skyine GTS-T
    91 Nissan Skyline GTR
    92,93 Nissan 180sx
    89 Nissan Silvia
    We sell the Works Bell ones if interested. You need a steering hub adaptor, as well as the quick release from Works Bell.
    RightDrive Inc. Parts Manager
      Are the hubs only compatible with aftermarket steering wheels or OEM one's as well?
      1989 R32 GTS-t (Sold)
        Daryl i bought one from you a couple years ago so im glad you have what i need. Do you know if this one will fit a nardi wheel?
        92,93 Nissan 180sx
        89 Nissan Silvia
          Normally only aftermarket, OEM steering wheels attach with a single nut on the end of the steering shaft.
          1989 R32 Skyline GTR SOLD!!!!
          -Bruce Lee
            i seen a guy take apart his OEM steering wheel for an integra, then drilled 6 holes to line up with quick release hub and then did it like that, was actually pretty neat.!
            Figured I'd show how I did mine :) This install is for the NON-SRS ITR Steering Wheel after people see how easy it is, the market for ITR wheels will be scarce INTRO: I am a steering wheel *****, and out of every single steering wheel I have ever owned, the JDM ITR NON SRS Wheel is by far the...
              Yes, only aftermarket.
              If you have one that you purchased from me, then yes, it will fit a Nardi, Personal, Momo, Sparco Key Racing, Works Bell, or Auto Select wheel.
                Thanks for the info Guys.
                  Daryl you have a pm
                  92,93 Nissan 180sx
                  89 Nissan Silvia
                    Quick question, Its been a while since ive had a car with hicas. Does that require a special hub or will an Nrg innovations hub fit just fine?
                    thanks
                    92,93 Nissan 180sx
                    89 Nissan Silvia
                      I have an NRG quick release and the quality is very good. Zero play, locks in with a snap. That damned hicas light will come on, but you can pull the bulb or cut a wire if it bothers you. 1990 gtr BTW. The best thing is it moves the wheel forward. Alot of non-japanese drivers (ie. Tall) can't get in a good driving position due to legs/wheel interference. This will help.
                        thanks
                        Check this video:
                        You guys think the same NRG parts will work for a R34? I think the steering rack, etc is the same between the R32, R33, R34..
