Has anyone seen this? think it would work with a R32?
Race past your weak stock settings with the DiabloSport inTune Tuner
Custom engineered with precision tunes that dramatically improve your horsepower, torque and MPGs
Pre-loaded tunes for various octane and power levels—no custom tune required
Running twin 32-bit processors, it’s the fastest, most advanced tuner in town
Loaded with 1GB of memory to hold an almost unlimited amount of custom tunes and data logs
Measures and stores your performance, allowing you to dial in the perfect settings and show off your results
Equipped with a high-res color touchscreen display with intuitive menus for simpler tuning
Built into a stainless steel body that’s smaller than most smartphones
Creates and stores custom tunes
Works as a scan tool to diagnose problems and clear fault codes
Connects to your computer through a standard USB port
Gives you access to free online updates
Leaves behind no trace in your system and won’t raise flags when you go for factory service
New MPG Booster tuning technology increases fuel economy by 1-2 MPG on most gas vehicles
New Throttle Booster Technology allows for user modification of throttle response and feel (Dodge makes only)
Works as a scan tool to diagnose trouble codes on any 1996 and newer vehicle (all makes)
Made in the USA
Your DiabloSport inTune tuner is backed by a 1-year warranty
Description
Ever feel like your gas pedal should have greater gusto, better response, and a more ferocious bite? Unlocking hidden horsepower from your powerplant has never been easier – or faster – than with the DiabloSport inTune Tuner.
DiabloSport’s cutting-edge inTune Tuner takes performance programming to the next level by mashing state-of-the-art components, a mountain of memory, piles of pre-configured tunes, and near limitless data logging into a single, portable device that’s smaller than the average smartphone. Whether you’re inputting a fresh tune, checking out your speed stats, or checking up on that Check Engine light, the inTune’s touchscreen display and user-friendly interface make in-depth programming easier than ever.
Fast is the DiabloSport inTune Tuner’s middle name. Not only does this performance tuner goose your horsepower and torque, but it also does it in record time thanks to its dual 32-bit processors. Better yet, you can connect your Diablo inTune to your computer and download an unlimited number of updates, including new tunes! And, it’s backed by a 1-year warranty.
comes with handheld looks kinda like an iPod Touch WHOLE Package for $400.!
Made in the USA
Description
