Anyone ever run a tuned RB20/RB25 on C16? Was the difference notable/worth it? Wondering also if the car has to be retuned to run C16 as opposed to pump?
RB25 on C16?
Originally posted by MKIV View PostAnyone ever run a tuned RB20/RB25 on C16? Was the difference notable/worth it? Wondering also if the car has to be retuned to run C16 as opposed to pump?
I have used C16 and ms109. I prefer ms109 due to cost, being oxygenated & availability where I am. It depends what is "worth it" to you. A tank of ms109 cost me about 3.7x what it costs on pump. It is not cheap, not something you want to waste when its in the tank. But you can be much more aggressive with timing and really crank up the boost.
You absolutely should make the adjustments for the fuel. If you don't you are not reaping the benefits and you may as well have just put pump gas in the tank.
C16 = o2 sensor failure. E85 if you can get it at the pump.
With ECU tune, 98 / E85 mix, roughly 50hp gain on RB20DET at same boost level (before is post 272 and after is post 276) -
On an unopened RB25DET, up to 400rwkw / 536.4rwhp is possible with E85 and have to change oil to match (I think someone mentioned running Motul oil, but double check that with an E85 expert).Last edited by Skym; 01-23-2012, 04:45 AM.RESPONSE MONSTER
E85 is at very few stations across Canada. When I checked early last year it was 4. May as well rule that out.Originally posted by MKIV View PostIs E85 cheaper than C16? I'm not familiar with any of this sorry.
Is Water/Meth cheaper than a higher octane tune?
Race fuel requires a tune, so does water meth. Water meth requires spending the money on the tune and all the associated equipment, but it is dirt cheap to run.
Weigh your options, consider what your car is used for, and look at cost/availability to decide what to use.
