hey guys so i have an RB20 basicly stock so far have a 3 inch exhaust cat back, and in the next few weeks adding an rb25 turbo with an rb20 wastegate, and a blitz atmospheric bov as well as keeping my stock reserculation valve. can anyone tell me in a ball park region what to expect for hp, as well as if the rb20 wastegate on the rb25 turbo will make any difference as well as hte atmospheric bov being used with the reserculation bov. thanks for the help
question about hp
if your going to be a smartass why did you respond to this...was basicly asking if it would work properly with the bov set up like that because that is how it was set up in the car my motor came out of1991 skyline GTS-T - first import/winter project
Depending on boost you should run from 250-300hp on that setup. If you have a Oem blow offf valve and one going to atmosphere block off the Oem location and make sure it's sealed. If not your car will be prone to stalling out.Miss driving sooooo bad! Need to get a car on the road ASAP!
I imagine you have a t off for the hose right now going into both bov's. Block the Oem blow off by welding a plate on there or something like that and get rid of the t and run the one line for the bov.Miss driving sooooo bad! Need to get a car on the road ASAP!
yea right now i just have the oem one but i was told without the oem reserculation valve i would have issues...but if i dont need the factory one at all then i will make an adapter plate to put the atmospheric bov in its place1991 skyline GTS-T - first import/winter project
ok , first dont run a recerc delete with out a tune it will stall at lights or whenever you stop ...could up the idle rpm but idk if it will stop the issue, also if you dont use your recerc it will take longer to get on boost after shifting bc you loose all that air
as for the waste gates the rb25 gate opens at 7psi and the rb20 at 10 psi so swaping them out would be a plusTO GRIP OR NOT TO GRIP.... THAT IS THE QUESTION
RB25 turbo is similar to hybrid RB20 turbo, so should add roughly 20hp more at same boost level and catback exhaust provides roughly 13.5hp or so with 0.1bar or maybe slightly more increase in boost level.
215hp + 13.5hp + 20hp = 248.5hp or close to 250hp (at engine) as mentioned above. Might be more if stock BOV doesn't leak.
Can modify stock BOV so it doesn't start to leak after 10psi or so -
Some fit 2x BOV to get the GTR 2x BOV sound or to remove all air between throttlebody, turbo so doesn't make turbo slow down too much.Last edited by Skym; 03-13-2012, 07:55 PM.RESPONSE MONSTER
