hey guys im fairly new to the rb25 motor.. ive had ca18s and ka24ets but this is my first rb. I bought a r32 swapped with a rb25 with wiring problems and blew the stock turbo right out of the gate.. So i have finally finished my mods to fit a Precision 5252e on it. Mods include :
walbro 255
5 bolt downpipe 3" straight piped and dumped behind front wheel
2" screamer pipe
External wastegate
3" intake with stock maf
greddy fmic 2.5" piping.
Just curious if anyone knew with this setup what a fairly safe boost level would be to run..?
How much boost and how much power can i make before i max out these injectors with that turbo? im ordering a wideband for it this weekend
Specs on turbo:
• 59mm inducer compressor wheel
• "E" compressor cover 3.0" inlet/2.0" outlet
• T350, 76 trim turbine wheel
• - T3 .48 or .63 A/R with 5 bolt discharge (without wastegate hole)
• 360° journal bearing system
Thanks in advance. ive searched and cant find anything with my setup that i could really go by..
walbro 255
2" screamer pipe
External wastegate
Specs on turbo:
