Bov for my 95 gts-t rb25 r33. Yes/no what kinds? Is it worth it?
  • Bov for my 95 gts-t rb25 r33. Yes/no what kinds? Is it worth it?
    I'm looking to get a bov for my skyline. I'm wondering if I should. Does it effect performance any? I heard its better for your turbo. I want to get more info on it before I do anything. I have a guy offering me a bov off a 240, I'm wondering if it would fit my car, or if I should even bother. Any info is appreciated!!!
    It's the mind that makes the man, not the color of his collar!
    95 GTS-T RB25 R33
    Apexi power intake, stage 2 clutch kit, HKS exhaust, Mishimoto rad, DBS 4000xs rotors, yellowstuff pads, HEL stainless lines.
    search it has been covered a million times. short answer is while your running a maf based system dont run an atmospheric bov or your car will run like crap
      not entirely true... i run a atmosphere vented BOV on my rb20 and it runs perfect, like a tiger, purrrrrrring
      btw i run a greddy BOV
        If stock BOV leaks a good aftermarket BOV will make a difference with hp, torque throughout powerband and transient response / hp. The increase in hp, torque comes from a leaner A/F ratio (more air entering engine instead of getting diverted back into rubber intake piping infront of turbo).
        I would suggest fitting a Synapse BOV, as it releases pressure properly when on boost or slightly offboost (just under 0 on boost gauge) which makes a big difference to pickup when get back onto throttle (transient response / hp). Also can be set to be push type (like factory BOV, if want overboost protection) or pull type (so it won't leak under boost and boost keeps valve inside BOV closed). Also has no diaphram that is affected by engine heat (more for racecars that experience high engine bay temps).
        Synapse BOV kit for RB25DET -
        I run the older type Synapse BOV on my car and works the same as on the day it was installed.
