Well i have just finished making the car reliable as my daily driver and now im looking to get a little more power. Dont have high power goals, just looking for a bit more and would be happy around the 300 mark. Haven't been to the dyno yet but figure its probably just over 200?
1994 gts-25t
Current modifications:
- 3" exhaust no cat
- Coilovers
- Apexi pod filter
- Splitfire coilpacks
- Manual Boost controller 10psi
- Sard rising rate FPR
- Walbro 255lph fuel pump
- Emusa FMIC
- Cometic triple layer metal exhaust manifold gasket
The next parts im looking to get are:
- 550cc injectors
- top mount manifold
- bigger turbo (suggestions?)
- front facing plenum
- stronger head studs and gasket (needed or not?)
- stand alone ecu
- electric boost controller
- new clutch (suggestions?)
So thats where im at with this so far. Unsure which turbo im going to run right now, want to go bigger and run a bit more boost. and also not sure if i will need to upgrade the head studs and gasket or if they will be sufficient for a bit more power. Also my clutch is stock and starting to feel worn out so it will need replaced, want something a bit stiffer that will work fine for my application. just looking for some suggestions for now about those parts and any parts that will need upgraded that i have overlooked.
1994 gts-25t
- 3" exhaust no cat
- Coilovers
- Apexi pod filter
- Emusa FMIC
- 550cc injectors
- stand alone ecu
