Iam gathering part for the build and Iam clueless about what too look for when buying a top mount manifold. What are the downside of buying a lower cost manifold ? What are you running or suggesting. I am planning on pushing in the 500whp range.
Exhaust Manifold top mount rb25 suggestion
Upside of buying cheap manifold is cost. downside is poor fitment, making expensive rework likely,and likelihood of welds cracking high.
A T4 flange manifold would be a good size. You can look into either twin scroll or quick spool valve to help with spool.
Wastegate sizes vary with 38 to 60mm sizes for regular manifolds. I would personally prefer 321ss for material however lost manifolds are made of regular carbon steel or 304ss.
I have a lovefab manifold that should fit Rb25 for sale. check my FS thread if interested.
Sent from my MB860 using Tapatalk 2Last edited by PurpleStreak; 10-02-2012, 11:56 AM.
Only top mount exhaust manifolds that are known to be good are :-
6boost -
6boost Exhaust Manifolds - Supplying the World's Best, Australian Made Aftermarket Turbo Exhaust Manifolds
Sinco customs -
I think both brands are made of thick steam pipe for runners and have thick flanges so they don't warp. Only problem is they are heavier than cheaper aftermarket exhaust manifolds.RESPONSE MONSTER
If search web, sometimes cost is mentioned.
Also probably would need a adjustable tension bar or similar from engine mount (metal part that bolts to engine) to turbo flange and a flexi in front pipe, just like what is used on Honda exhaust's to not snap exhaust studs or rip them from head.Last edited by Skym; 10-03-2012, 05:45 PM.RESPONSE MONSTER
RB25DET engines with that sort of hp have RB26 crank, RB26 H beam conrods, RB26 forged pistons inside stock RB25DET block, 1.2mm metal headgasket. Cams used are the same as RB26, so Tomei 260 duration cams with adjustable exhaust camgear, Tomei valve springs, Tomei solid lifters should be good enough for 700hp at engine.
Basically what mods work on RB26DETT, works on RB25DET as far as fuel, bottomend, intake manifold (Can fit stock RB26 intake plenum with adaptor plate), cams go. Basically you are making a RB26DET out of a RB25DET (better to start with RB26, as less work involved and have solid lifters, etc). Turbo, FMIC are sized to suit powerlevel.
Or you can fit a RB30 bottomend (more hp, torque than RB25, RB26) -
Size of intercooler core vs hp you want (turbo + engine combined) is here -
Then search for turbo (right side) that matches the hp you want and research at what rpm full boost is on that engine -
Injector sizing calculator is here (stick to 80% duty cycle max) -
Target Crank HP kW PS # of Injectors Induction Type Turbocharged Supercharged Naturally Aspirated Fuel Type Gasoline Ethanol Methanol Ethanol Blend E98 E85 B.S.F.C. Value (optional) Max Duty Cycle (%) Injector Flow Needed 0.00 cc/min Reset Target Crank HP Induction Type Naturally Aspirated Turbocharged Supercharged FRESPONSE MONSTER
I bought one of thoes 170 dollar eBay manifolds. I had to cut and re angle the flange for turbo clearance and I also added a bigger port in the collector for wastegate and better boost controll.
There's definatly something to be said for buying brand name products.Built R32 GTR, BW S362, 682awhp @ 28psi
Try ETM manifolds too, merge collector design's a bit better then the 6boost (dont get me wrong 6boost are awesome). Powertune here in aus also make a nice manifold and can custome make with the appropiate flanges/wastegate ports.
One tip ill give you is to use the OEM nuts and yokes when fitting these manifolds as the nuts supplied will tend to seize unless copper coated.
A friend of mine is running just under 500hp (480 @19psi) with a stock internalled RB25. His running a garrett GTX3582R, 640cc nismos, bigger fuel pump, plazmaman plenum, PowerFC with z32 AFM, bigger cooler ETC. Does 3rd gear stand still's but is now having diff troubles as he keeps snapping shafts/gears. As I said the engine is bone stock and has only had 1 engine fail due to hitting limiter and breaking valve spring retainer which intern dropped a valve. $1500aud later and his got another stock engine in there and its still going strong.
Heres a clip for your veiwing pleasure.
