I have a hybrid RB20 stock turbo on my car and engine is very responsive (with transient response) vs stock turbo (same feeling as with stock turbo, just feels alot stronger, quicker when car accelerates). Boost response is slightly laggier than stock, as it starts to reach 0 on boost gauge at 2500rpm (can keep turbo off boost for better fuel economy), full boost at around 3500rpm and peak hp at 7500rpm (produces around 270hp at engine with 12psi or basically 20hp more at same boost level as stock RB20 turbo with intake, 3" exhaust from stock dumppipe, bov mods, stock ECU tune). With intake, 3" exhaust from stock dumppipe, BOV mods, stock ECU tune, stock RB20 turbo it should produce 250hp at engine (varies from car to car due to internal wastegate being different on each car).
Hybrid RB20DET stock turbo should be capable of 350hp at 1bar (20hp more than stock turbo at same boost level with boost up mods) on pump gas and around 400hp with E85 at 1bar (those hp numbers are at engine and with boost up mods like Z32 MAF+Z32 MAF plug, retuned stock ECU, injectors, fuelpump, FMIC, full 3" exhaust from turbo, boost controller, upgraded clutch).
Hybrid RB25DET turbo has the bigger compressor wheel, so produces more hp at same boost level as hybrid RB20 stock turbo or basically can run lower boost level for same amount of hp. On RB25DET it's been known to produce over 400hp at engine at 1bar with Link ECU (map sensor, etc), HDI FMIC, Subaru? injectors, aftermarket fuelpump, intake, exhaust mods, clutch upgrade. But it is also known to surge unless drive to prevent it from surging (due small A/R exhaust housing with bigger compressor wheel). You could fit bigger A/R exhaust housing from VG30ET turbo to solve it, but might lose response (might not on RB25DET due to RB25DET produces more exhaust gas).
