so a few months ago i took the plunge and got one of these freddy front facing intake manis.
so everything up till this point is spot on. the bolt holes line up and even the supplied bolts are the proper threads and offer the proper seal.
but my front freddy manifold for my rb25 is leaking. what are the tq specs for these things seeing as they come with thier own bolts. anyone know???
every time i start my car water spews down the block. iam going to tighten up the bolts.
but on the water neck did you guys use rtv or teflon tape?? seems it's leaking from the manifold side on that sleve you slide in for the coolant hose.
so i went ahead and coated the neck with rtv
hopefully that will stop that neck from leaking. iam gonna wait and let the rtv cure before trying it again.
