I have done some searching and only cobrAA has had the same issue as me. I have installed an oil cooler and thermostat with oil filter relocate. The oil temp. gauge is Prosport. I have no idea what oil temp. was before. Just cruising around at over three thousand rpm my gauge runs about 200F to 215F oil temp. Coolant is at 170F to 175F. Why such a difference, is there some way to check oil sender/ gauge for accuracy? My afr at this rpm is high 12's to low 13's. Car runs great and oil does not smell or is off color. A bit concerned about the indicated high oil temps.
Any comments appreciated.
