What should the oil pressure of a rb20det be? i have tried searching but couldnt find anything. i recently installed a innovate oil pressure and temp gauge so im just trying to set it up and trying to find out what normal is
oil pressure?
im geting about the same. i think my stock gauge was pooched as when im driving its at +8 and at idle its just below +6. with the new gauge im pretty close to your numbers but im using 5w30Originally posted by craftz View PostI have 10w30 Mobil 1 and when I first start up it's 60psi. After warm up and cruising at 2500 rpm around 45psi. At idle, about 20psi.Check out Top Tier Imports. Sign up today! http://www.toptierimports.com
