hey guys I'm just order solid lifters set and cams and valve springs for my rb25det. question is i order the procams 260 9.15 lift and the guy recommended the type b 10.25 lift dual valve springs.. would that even work?
rb25det head work need help
Tomei recommend those Type B valve springs for solid lifter camshafts in RB25DET head -
Also, don't forget these -
Also don't forget the shims, check lifter clearances after engine has done some km and change shims if necessary.
Degreeing cams -
Need to optimize & tune your engine to gain maximum horsepower and torque. Unlock serious RPM potential with high performance Kelford Cams.
Break in procedure -
