Godspeed Intake Manifold.
  • Godspeed Intake Manifold.
    I have just bought i Godspeed Intake Manifold for my Rb25det and had it installed at a local tuner shop. I'm curious if the intake manifold has coolant lines like the stock intake manifold rb20-25 have. The only reason i ask is because my manifold is hot to the touch after a drive to work but my front mount inter cooler is ice cold. So is there coolant lines to these aftermarket manifold or is the engine just that hot? Any feed back would be appreciated.
    Thanks.
    1990 Skyline Gts
    If anyone wanted to know now i did figure it out. There is a coolant hose that bolts on from the up rad hose and does flow threw the bottom of the intake manifold. which would explain the above normal heat.
    And now you know.
    1990 Skyline Gts
