so I blew a head gasket , and then this happened.
so in a miracle my car runs and drives fine, except!!!!
when I get to a certain psi(13-15) then the cur hit's a hard cut. I thought maybe it's my tune. so I richen it out to 11-10afr right before cutoff, but the cut still happens, I lean it out a little and still I hit a cut.
This happens when I run 91-93 octane fuel. If I got less than premium I would only be able to boost up to 8psi.
then I had my buddy modify my nistune map and do something with the timing. and now even in low octane now I can only get 13-15psi.
I can't get to w.o.t. in boost. I can get over 100mph and I can spool but I have to stay in the 10psi range.
my stock injector duty cycle isn't hitting over 50%. so iam not running out of fuel.
but soon as I spool higher, I hit some cut. now iam not crazy, so on the rpm and mph cut I raised on the ecu. also I was told to adjust my tps. it's from a infinity q45.
and here's the wot tps reading.
so I heard from my head shop guy that since he took off 16 thousands. And if I used the stock head gasket,this would raise the compression. By how much?? I don't know??
well this is what I did, so has me raising the compression cost me some boost pressure???
heres my mods
-rb25det with-
-z32 maf
-nismo fuel pressure regular
-wally 255lph fuel pump
-freddy intake mani
-q45 throttle body
-nistune ecu z32 n/a
-3" exhaust
-front mount intercooler 3"
heres my mods
-rb25det with-
-z32 maf
-freddy intake mani
-q45 throttle body
-3" exhaust
