Non ABS model R33 GTS25T. On the front knuckle there is a dust cover on the rear, under that is a large nut with a 32mm head, and directly under that is a round washer that is keyed in the center. (hub nut and washer) I need to order those washers but I dont know what they cross reference with in the USA so I need the actual part number. (Z32 is the same key size but it is thicker and has the ABS teeth on it so I cant use it.)
Help need a part number out of fast, my PC wont load it - R33 GTS25T non ABS
