drivers window wont roll up
  • drivers window wont roll up
    hi there, so my drivers window wont roll up as of today, seems the window motor stopped working, now is there a way to roll it up by disconnecting some parts or something, so it can be up while i wait for parts
    thanks
    I think it is usually the contacts to the motor that need cleaning (common problem, alot of contact's with switches on the car have this problem).
    You can pull the door skin off (screws) and I think roll it up manually.
      The only way I know how to roll up a power window motor is to disengage the motor from driven gear of the regulator and install something that will turn the sprocket ...easier said than done because skyline window reg motors face towards outside door skin :$ best bet disengage the bolts that secure the glass to the regulator and prop the glass up with a 2x4 cut to length OR a mallet to the motor while you play around with the switch. ONE of these methods should work , I hope
        thanks i ended up disconnecting the regulator and just manually using the window till a new motor comes in for it
