Gts-t redux
    little bit of labbit to finish things off.
    1/1_Scale
    パーソナリティは、1つを得る
      looking good Chewy.... those works look tight on that
        Thanks dude! need lower offset though...hmm, new wheels or spacers.
        1/1_Scale
        パーソナリティは、1つを得る
          sick car your in victoria?
          (O▫O)SKYRINE(O▫O)
            Thanks, yeah I'm in Vic. Car hasn't been inspected yet. Pulling the trans and replacing the Clutch slave along with T/O bearing. Should be done, insured and driving next week.
            1/1_Scale
            パーソナリティは、1つを得る
              Same goes for the wheels haha. PM me if you end up selling. Ya, I'm THAT guy.
              Team Limit - "Wide Fuckin' Open"
                Been a while, but I found some cool **** from the previous owner in Japan,
                Found out the car has an R33 GTR fuel pump, a RB25 series 2 turbo, er34 compressor outlet, URAS tie rod puzzle rings, and BNR32 upper links for more camber. Oh, and the exhaust IS a Kakimoto N2000 Dual. Also painting valve covers, should be super sex, more pics tonight!
                Finally bought these two to start replacing stuff that mysteriously went missing
                1/1_Scale
                パーソナリティは、1つを得る
                  Valve cover pics,
                  going to polish center section and cut in vents when I have a bit of time...Strut bar needs a polish too, gotta get down to businesssss
                  sparkle sparkle
                  1/1_Scale
                  パーソナリティは、1つを得る
                    Installed Defi Gauge and Blitz SBC R, had some issues setting the gain to begin with so hopefully the gooftard r33 turbine nylon impeller holds it's **** together,now running a solid 1Bar with NO SPIKES WHATSOEVER when referring to the datalogging, and to top it all off, she breaks loose into 3rd.
                    1/1_Scale
                    パーソナリティは、1つを得る
                      hello,
                      i have little question.
                      does the cr kai 17x9 +28 fit without spacer on the hcr32?
                      greets
                        it doesn't fit qute so well. The front has a spacer, the rear however does fit ok with -1degree of camber which was achieved in my case with some RUCAs.
                        1/1_Scale
                        パーソナリティは、1つを得る
                          Whats the status on the car now?
                          So if i have 18x9.5 +25 (rear) and 18x9 +28 (front) going on my car. I should be ok right (r32 gts). I have rolled the fenders already, but not pulled
                          Originally posted by m_melen
                            thank you,
                            does de spokes comes against the caliper?
