The Candy Man
  • You could turn the boost down a bit couldn't you? It might help with the whole maxing out injectors thing until you pick up new injectors and a z32 maf.
    • Im no expert with engines and stuff. i know a little bit
      but me turning my boost down wouldn't do much. No matter what the boost setting, my injectors max out at 5800 rpm. turning the boost down would only make it so it would take longer for me to reach that point.
      Now yes. if i turned the boost down a lot, like to 5 psi or something. i could see me being able to go into a high rpm range.
      But i still don't really no how to work the boost gauge, but i would assume that if i fiddled with the duty cycle and spring pressure, i could find something that works for my current setup until i get injectors.
      but with this all being said, i hardly ever go that high. If i do a "pull" on the highway, i usually shift at 5000 or less
      Originally posted by m_melen
      • So new injectors should be here soon. Its actually a gift from a buddy so i don't know the brand or size but i think they are around an 800cc.
        Im hoping i can have them in before winter and then get a tune before winter. But only time and weather will tell
        • lowered it and removed wings.
          I lowered it an inch all around.
          I rub in the front so ill be carefully rolling the fronts and probably rears tomorrow
          • Big improvement in my opinion looks alot better, good job
            • i think so too.
              so I have a somewhat outline for the winter.
              nothing to crazy. Number 1 on my list tho is a proper tune. I strongly believe that a proper tune makes or breaks a car.
              in order for me to get a proper tune i need to get a z32 maf and bigger injectors
              I would really like some new wheels but i don't know if ill have enough cash flow to support it as well as get parts for my 240sx
              the last thing the car needs is a new diff. A stock one is fine for now if i can find one for cheap. I just need one that isn't worn out so i can actually get grip
              so a general list will be
              500cc or bigger injectors
              255lph walbro fuel pump
              Fuel pressure regulator
              Z32 Maf
              TUNE,TUNE,TUNE
              if i can afford it
              Wheels (if i can't fund new wheels, ill space current ones out)
              get hood painted all blue
              Get new (different) hood pins
              pretty much all my money i make will be going towards my 240sx, my skyline, and my 4runner. mostly skyline and 240 tho
              • looks good dude! I had mine just as low as that, and hellz yeah it looks reallly nice. But I quickly realized that all of lethbridge's road construction workers were drunk while working. Seriously I think I caught air going over whoop up yesterday. has it been pretty rough with it that low?
                • I have a GTR helical LSD. let me know if you are interested..
                  • looking good.
                    RB25 Powered RWD GT-R
                    • Actually its not that bad. I was rubbing really hard so i rolled the front fenders, but then i also tightened up the springs so i reduced the rebound and that raised the front up a bit, and it still looks good and no rubbing. Prior to that i was scraping all over town.
                      • hey i got some sparco hood pins i dont need
                        • Wheels got spaced out yesterday, which meant fenders had to be rolled. DONE AND DONE
                          Rear is Flush, and front has a little bit of poke
                          • I have a stock LSD from a GTS-T, plug and play.
                            I also have a lot of other little things lying around to, depends what else you have on your wish list.
                            • Hey. Wanna send me a text about parts
                              • get the pins yet?
