The Candy Man
  • K so for some reason Mac's don't like memory card readers and mom lost the cable for the camera. HMMM ill try something different tomorrow but it doesn't way different on camera, not as cool
    anyway
    found some Deatschwerks injectors 550's for 400 bucks. Used of course, my only question is that these should be good enought for my car right. My goals are only like 350hp
    Originally posted by m_melen
    • 550 is plenty up to 450bhp. Also, stockers are 269.
      • SO 550cc Sard injectors will be on there way from Adam @ feast.
        Fuel Pump is on its way.
        Ive already recieved my Hicas lockout bar so i will be attempting that sometime this week (Not sure which route to take)
        Is it easier to just loop the Hicas lines at the rear of the car?
        And oil cooler will be installed as soon as Braden @JNS imports gets back to me
        • Originally posted by RHDskyline View Post
          Just do it "right" and remove everything.
          Team Limit - "Wide Fuckin' Open"
          • hicas is an easy delete. let me know if you need help. ive done it 3 or 4 times now.
            RB25 Powered RWD GT-R
            • im following one where i remove all the lines under the car and loop it from the cooler to the rack or something like that
              thats the one im following
              • what a mess of hoses. that kid is dumb. REMOVE EVERYTHING HICAS. then take off the back of the pump pull out all of the little squares then weld shut the rear outlet on the pump. < shits done properly
                but if you like the ps cooler then you have to make lines from the rack to the cooler then to the resevoir
                • I followed that guide exactly and everything worked out perfectly. No more Hicas. No hicas light and now i can drift properly.
                  So thats one less thing to do on my skyline.
                  On a side note. I did receive my clutch for my sr20, so that will be going into my 240 sometime next week hopefully.
                  Injectors, fuel pump, and FPR adapter are in transit.
                  Does anyone have good recommendations for multilink adjustable suspension for the skyline?
                  • Driftworks! Or Canadian products like Bings you can pick up most of the items needed.
                    92 Gtst/Silver bullet
                    • +1 on bings
                      • Got any pics of your exhaust set up? I love the dual 3 inch pipes sticking out the back.
                        • Ive been trying to. My photobucket is being really lame so its not working. When i get a chance to again i will try
                          • Those are the only two that would load
                            I just don't like how the pipes look so small. When in fact they are both 3 inch pipes. Maybe i should have gone 3.5?
                            • Think it looks great and 3" looks to be quite large enough. You don't want them too big because you will start attracting un wanted attention and get yourself in sheet
                              • Yeah you are right. And hey. I never see the exhaust anyway, im always driving.
                                So there i am. Working on my sr20 getting it all ready to put in 240, when my step mom comes in with some mail I know what that means. It means my parts are finally coming in.
                                So in the one envelope, i know its my fuel rail adapter so i can run my adjustable FPR.
                                But in the other box, i can not for the life of me think of what it is. (ive ordered so much stuff) haha.
                                So i open it and its my fuel pump. WTF.
                                For some reason. I had this idea in my head that fuel pumps were really big. But they are just so small.
                                So after i get my sr swap done i plan on changing the fuel pump out, hooking the FPR up, and by then, my injectors should be in from Adam and i will be set. Or atleast till spring when i can get a real tune. FINALLY. Ive been waiting for a real tune since ive gotten the car
