R33 Build/Project/Whatever happens
    just a refesher.. its a solid motor.. and taking the head off.. no concerns it should be happy for awhile.
    the timing belt as a fair bit of slack in it. (I have a pic on here somewhere)
    so ya.. cut it.. lol..
    ________________
    FVI Fo Life
    Originally posted by JZ
    _________________
      Parts arrived at the Cuzins in the USA.. Went down last night..
      Brought back a lot of stuff. Customs = 0, Dah_Hunter = 1,000,0000 LoL..
      Guages/wastegate
      Head Studs
      Turbo Rebuild Kit
      The Brain of it all
      WideBand
      Gasket Kit
      Still waiting on Front Mount Intercooler, Plenum.
      Still have to buy, Timing Belt, Front Main, Freeze Plugs, Injectors, Fuel Rail. Fuel Pump, Fuel Filter.
      ________________
      FVI Fo Life
      _________________
        Heads off to get a refresh.
        Falcon is rebuilding the turbo..
        Its almost time to start putting things back together..
        (Has to be at least 10 Degrees out first)
        ________________
        FVI Fo Life
        _________________
          Nice build man, pretty much identical to my car and its giving me alot on insight before i start taking mine apart this summer lol thinking of going along the same basis for mine as well. good idea with a refresher first. GLW build and keep posting pics, gonna keep me from running into problems lol
          Note: Turbos make torque and torque makes fun
            lol. glad i can be some help..
            im just doing whatever..
            Just ordered..
            New Freeze Plugs..
            OEM Timing Belt/Tensioner.
            Front/Rear Main seals
            Cam Seals
            Also modifying the Valve covers to change the oil blow back route.
            ________________
            FVI Fo Life
            _________________
              man a pon cam should be sick for that build!
              Lookin' good! Yeah I agree it's a bit too chilly for us Vancouverites atm... wtf is -1C!!!?!!
                Yo Mike. Your motor is VVT right? Is it just activated with a 2 wire solonoid? Trying to figure out how to get this to work. The Haltech has a universal output that can be used for "VTEC" (that's just the word used int he programming) but it should do the same thing since Honda VTEC is controlled by a solonoid. It has a whole RPM setup section, PSI min/max etc.
                TROL
                  Front mount Arrived
                  Plenum Arrived
                  Freeze Plugs
                  Fuel Pump
                  More pics to come (Of parts only, to cold to do any work)
                  ________________
                  FVI Fo Life
                  _________________
                    Aaron, I don't have VVT. RHDjapan shipped me a cam that is made for VVT, which Ben's car would appreciate very much
                      Couple Pics..
                      New Plenum:
                      Fuel Pump and Freeze Plugs:
                      ________________
                      FVI Fo Life
                      _________________
                        New 555 Injectors on the way.
                        dual Core Rad
                        Yellow Jacket coil packs.
                        ________________
                        FVI Fo Life
                        _________________
                          Nice ben. Any idea what size throttle body that is?
                          TROL
                            Looks like a 90mm or 80mm at least.
                            92 Gtst/Silver bullet
                            • #29
                              Injectors, Timing Belt, Coilpacks have arrived.. almost time to start putting things back together..
                              ________________
                              FVI Fo Life
                              _________________
                              • #30
                                If it is the same as the one used for greddy which it looks to be a greddy then it is a q45 which is a 90mm throttle body(or true reading of 86 something mm)
