ok so i have recently purchased MKIV's r32 GTST with the following work done.
(stolen from his build thread)
So since ive purchased the car (about 48 hours ago haha)
-Fixed a few small things, im a bit of a detail freak, rear window was rattling and making lots of squeaks, reglued a little in the back pass side window.
-Removed a home made bracket that was hiding behind the speedo and making some sort of aweful noise over any bump
-Remounted side skirts as they all seem to start to come off over time
-While in the GTA purchased some strut bars off another GTRC member, they were pitted ugly and just needed an overhaul so i spent all last night wet sanding/polishing the front came out quite nice, aside from a few larger dings it looks like a fresh chrome one
now just have to put in the hours to the rear and it will be good 2 go!
-General wire clean up, worked some zip tie magic just tidying things up.
-Completely went over the car top to bottom and cleaned it, not like there was much though previous owner took spectacular care of this car.
-Replaced Shifter Boot
-Adjusted hood and front fenders (fits much nicer now) less gaps from conversion.
-Fixed Horn, was grounding out and staying on unless a shim was placed in the wheel.
TO DO LIST:
-Shifter has a weird issue, car stays in gear but the shifter comes loose has all sorts of play, replaced a ripped boot (3rd one down so last before the tranny) took it apart like 9 times in the last 10 hours trying to solve the issue and the little plastic cap on the end of the shift rod (idk what to call it) has been melted a little and it finally broke! I NEED ANOTHER!!
-GTR Quarters, going for that wide ass look, also throwing on some 285 45 18's for that rediculous look
-Repaint (same colour) just fix all small dings and little blemish's also make the gtr quarters fit proper.
PICS TO COME
Originally posted by MKIV
View Post
TO DO LIST:
PICS TO COME
