Well im starting up a new build with my gtst and the rb20det.
So far my mild engine build has gone a little past that but hey, its all in the pursuit of skyline happiness
My mods were pretty basic when i picked up the car but with some good, reliable ones as well.
It was running a standard rb20 with a nistune ecu, 440cc injectors, precision top mount turbo and 3" downpipe/exhaust. A gtr clutch for the standard rb20 transmission to handle a bit more power.
LS2 coilpack wasted spark system to compliment. Aftermarket gauges and sensors to monitor oil pressure and temperature and boost pressure. Fmic (big a** one), koyo radiator and z32 MAF. It also came with a sard fuel pressure gauge and z32 fuel filter.
So, all in all it was a good decent place to start.
I was driving with this setup for about 4 months when i started hearing a lot of noise from the motor and decided it was time to rip it out and start up a good build.
My parts list that i have ordered are :
Cometic full gasket kit top and bottom with 1.3mm headgasket
OEM piston rings (pistons were in near new condition = surprising!)
ACL bearings
ARP headstuds
ARP rod bolts
Full set of new hydraulic lifters
New oil pump oem
New water pump - raw brokerage upgraded one
All new hardware for everything through raw brokerage
Silicone radiator and heater hoses
Mishimoto colder thermostat
Ross tuffbond harmonic balancer through raw brokerage
New crankshaft gear - oem
New timing belt kit - oem
Nismo engine mounts
Im only looking for 350rwhp so im hoping this list of parts will compliment that for a long period of time and be very reliable. Im excited to finally finish it up and get a final tune done to see what this setup can make. im hoping to keep boost to around 14-15 psi and manage the 350hp as my turbo is quite large .70 Ar and .63 Ar.
Any advice is welcome on any further parts or ideas. keep in mind tho that this is going to be a daily driven car majority of the year besides the winter and crappy days.
Thanks
ACL bearings
ARP headstuds
ARP rod bolts
New oil pump oem
Nismo engine mounts
Thanks
