I did a search and found surprisingly little other than this is very difficult or not worth it. But when I break it all down I don't see how it's so hard.
GTT rb26 swaps are not uncommon and r34 trans into r32 33 is not uncommon either. Seem like starting with a donor r32 33 gtr parts into r34 should be just as possible or am I missing something?
What I know I'll need for major components.
Rb26 Engine
R33 transmision or r32 with 33 transfer case (speed sensor)
R34 awd sub frame, LCA, spindles and axles
Attesa pump on rear differential
Wiring and g sensors
Probably need
R32 33 rear diff or r34 front (differnt gear ratios)
R32 33 driveshaft
Random hardware, tubing, wires, hoses etc etc
For wiring it should be just a matter or doing an rb26 swap like any other online then adding the attesa wiring and g sensors for the transmission. I amagine this will be the most challenging part of the swap.
I have an r32 gtr engine trans and complete uncut body/engine wiring harness with all sensors. I keep thinking there's got to be something I'm missing or this would be a more common conversion.
Has anyone else done this swap or similar.
Rb26 Engine
Probably need
R32 33 driveshaft
