ECU Question...
  • ECU Question...
    Hey guys,
    I have Blitz Access ECU for my RB20DET. I decided to crack open the case. Once I got inside, I unscrewed a smaller chip connected to the main board by a wide and flat cable. On the main board, there is a chip that reads: R32 AT ....is this an ECU for an A/T RB20DET? Does it make a big difference between M/T and A/T ECU's??? Should I discontinue use of the Access computer?
    1992 NISSAN 240SX - RB20DET POWER
    1990 NISSAN 300ZX - 2+2
    Won't matter. The A/T will be fine.
    Did they socket the board, or just solder in the new chip?
    Originally posted by ARC240 View Post
    Hey guys,
    -= PM ME FOR INFO =-
      How can I tell if they socketed the board? I'm pretty sure they just soldered in a modified chip.
        Does the chip pull out?
          With automatic R32 Skylines, engine ECU gets a signal from auto ECU to pull timing during gearchanges. Without that signal, auto engine ECU should just run like a manual ECU. Also I think ignition timing is slightly advanced at bottomend for the automatic engine ECU.
            Mark, I am running an A/T ECU in my car and its perfect. That small "chip" that is connected to the main board thru a wide and flat set of wires is actually knock board. DO NOT mess with it, man.
            I dont know much about Blitz Access ECUs and how they are better or worse than stock ECUs, but you shouldn't worry about A/T vs. M/T ECu. All you will be seeing if you do a fault code test on the ECU will be code 54 (A/T signal), which is what Skym also mentioned.
            If you find the car running well with this ECU, keep using it.
            (O||O___SKYLINE___O||O)
            SERENITY NOW!!!!!!
              I'm not messing with any chips lol. The car runs well with this one, so I didn't think there would be a problem at all. Blitz ECU FTW, feels A LOT better than the stock one, I can tell you that much, there is a fairly noticeable difference, I love it. Funny you should mention the fault code issue...I'm currently running a 55 (everything good) lol. Which puzzles me a tad now that you mention it .
                Then maybe its not an A/T ECU........
                SERENITY NOW!!!!!!
                  Bah, whether or not it may be an A/T ECU is still unsolved. But the car runs fine, I'm not going to complain at all...idles a bit high, not much, but still idles, runs, drives great! Thanks for your input.
