Under WOT in second, third and fourth gears my car seams to stumble. Full boost hits and it pulls well, then the car slows (still WOT), then pulls again, and slows again. Its like a lack of power to the wheels. I don't think its the clutch because when it stumbles the revs don't shoot up, it almost seems as though they slow down. Boost stays constant at 12psi, fuel pressure is normal, AFR's are at 11/12. The one thing that may be out of the ordinary, is the exhaust temp. During easy driving it is lower than 300 degrees, as soon as the stumbling starts it climbs quickly to 500+ degrees. Oh, and the exhaust temp probe is located in my test pipe. I would like to know what to check, as I
don't have the faintest idea of what it could be.
Thanks,
Scott
Thanks,
Scott
