I just got my r33 GTS-T the other day and it needs new pads/rotors front and back.
I've been doing some searching online but couldn't get definite answers, i found some where someone simply says they are the same all around as the 300zx TT brakes...
so anyway, i searched up on dba and the GTS-T rear rotors are the same as the 89+ USDM 300zx TT rear rotors
1) does this mean I can also get the pads as well? as long as the pads fit the rotors, should be good right?
as for the FRONTS...I can't find one that is the same size rotors according to dba...
the gts-t front rotors according to dba are 296x53.7x30x68x5 sizing
I looked up for 300zx tt(280mm), 350z(non-track/brembo), and even the maxima(296mm but height and thickness are different)...
2) can anyone point me in the right direction with a definite answer for the fronts?
oh and bytheway, I can go 1-2mm thicker on the rotors right? b/c according to dba's website, for example, the thickness for their rotor shows as 18mm but then besides says "minimum thickness" as 16mm...so I'm assuming their rotor is 2mm thicker than OEM specs?
hopefully some r33 GTS-T owners can chime in here
