Still trying to diagnose the problems guys. Is there two or one o2 sensor on gtst? i have found one on the exhaust down-pipe.
High RPM Hesitation/Fuel Cut and Glowing exhaust manifold!!!!!
Originally posted by pmurr181 View Postso i am still trying to figure out the problem....
Does anyone know where i can get OEM or replacement fuel pressure regualtor for stock rb20
but give mike at 4Xtoys, he probably has something and would give you a decent price im sure, if not autoream orsomeone would have one.
honestly check for vaccum leaks, anything that would make a source of vaccum (not boost leak) will make your car run lean.
you may have to get a pressure tester and open throttle plate and set the regulator around 15psi and listen for leaks, or if you have a smoke tester works better.
yeah guys thanks for all the replys. I have done all the basics now i am looking further into it. its the stock exhuast manifold and i have no boost controller. Thank you fro all the help guys i will see what i can get for fpr and i will check for vaccum leaks
thanks
