Up until now, ive had no real issues, but today has been a handful!!
..Drove the car last night to my shop - Ran perfect, literally, under 15-16 lbs of boost @ 4 celsius, mint, no hesitation nothing..
Today, i installed my 3" split dump/downpipe with divorced wastegate to stock cat (for noise restriction
) to 3.75", no resonator, and ends with an HKS super dragger.. Also reused my oem EGT and installed a UEGO (before cat).
Took the car for a quick rip with only the downpipe because it sounded unbareably mean.. Noticed it back fired like there's no tomorrow; pop pop pop pop UNDER ACCEL. up until 4k. Never floored it to WOT because i was kind of worried.. Go back and install rest of exhaust..
......STILL DOING IT??
1. Normal driving, everything is perfect. AFR's are great etc.
2. My stock boost is now 15.9 psi.. EBC is off and peaked @ these numbers.
3. My AFR under WOT is 10.8-11.4 (decent)
4. I lose complete power at 5000 rpm under wot, right after turbo spools HARD.
6. New plugs (1.1mm though..) , compression is 141 across the board.
7. all ive done is installed a downpipe, fixed a massive exhaust leak, and removed the resonator..
What should i be looking for?? I was thinking vac leak but under WOT at any rpm it should shudder and show signs.. My car is literally just cutting out.
Also, the car continuously back fires, as if its over fueling. Everytime i shift, it backfires, everytime i floor it, it pops a bit then picks up.. I'm really confused!!!
Fuel cut off? ECU in safe mode? Maf not sufficient (stock) ?
ECU Was reset - no change.
