Bolt torque specs?
  • Bolt torque specs?
    Hi I am looking for the front and rear upper strut bolts torque specs. Searched 3 different forums with no luck.
    thanks
    Perhaps because the need for a real torque value is quite unnecessary.. Using a (14 i believe) socket and breaker bar (or 3/8th's half sized breaker bar, as long as it's not a ratchet as you'll destroy the mechanism), you can judge the proper amount by hand.
    Don't be shy to give it that extra pull, but over tightening them isn't necessary.
    www.nelsonmx.wordpress.com
      lol im with nelson, i think tourqueing stuff is not needed in most cases, i would be suprised if there is even tourque specs for those bolts.
      but give the manual a try anyways, its just a waste of your time, just make sure they are tight.
      http://gtrpwr.com/downloads.php?do=cat&id=2
        front upper strut nuts are 29-40 ft.lbs
        rear upper strut nuts are 12-14 ft.lbs
        1966 Pontiac Beaumont | 1972 Nissan Skyline 2000GT-X | 1990 Nissan Skyline GTS-T Type-M
        1991 Toyota Celsior C-Type Supercharged | 1991 Toyota Cressida | 2008 GMC Acadia
