So a fetched my driver side outer tie rod end up while replacing my Steering Rack boot.
Been doing reaserch and its been back and forth between the 300zx or Maxima tie rod end. Cant get a confirmed answer.
I picked up a 95 Maxima tie rod and it looks like the taper, thread pitch, and everything is all the same, however when you stand the skyline one up against the maxima one up the maxima one is shorter.
Does anyone know if the maxima one will work fine, or if i should keep looking. If all matches up as it does, the in theroy it should work and be compensated with a alighnment??
pics.
pics.
