ok so couple weeks ago my r33 gtst would completely shut off around 4-5 rpm in 4th gear. 1,2,3 are smooth all the way through. if i dont accelerate too hard in 4th, i can pull through fairly but around 5-6rpm the car jerks and wont let me accelerate. then i shift into 5th and same thing happens, but this time during the lower rpms (2-3.5).
We changed the spark plugs, and now the car doesnt randomly shut off. took care of that..
as for the restriction/jerk during higher rpms in 4th and right away in 5th, the problem is still there. The car wont accelerate and jerks and just looses power when i press the gas (like a flat spot). I cant even go fast enough to keep up with the cars on the highway.
ECU is tuned to 100 octane, but with 110 race gas same thing happens..
A stock ecu is on its way..will try that.
Buddy said it could be a boost leak under full pressure..?
Guy before me put 3" mid pipe with huge exhaust, but the front/down pipe is stock..which restricts airflow in the beginning. ill order a 3" downpipe soon..
everything else is stock except for intake and grounding kit.
Please help me out!!!
EDIT: PROBLEM SOLVED!!!!
