Could someone help me???
I have a problem with rear demister (heater for rear window) not working. The light on button (located above headlight switch on right side of top of dash) should come on and it's not, then suddenly it is.
I have a few idea's of what it could be -
1.) Fuse on way out due to earth problem (but can't find a earth problem, as fixed one earth problem I had in engine bay)
2.) Corroded switch contacts due to being close to window / moisture (common problem with headlight switch)
3.) Device using same earth as demister / heater and interfering with it's function (turbo timer is playing up, shutting off engine when turning key to off position on ignition barrell, which is a common problem if earth is done incorrectly with turbo timer).
What I need help with, is does the light come on straight away when you turn on the rear window heater / demister in your car (R32, GTS or GTR)??? Or does it come on when element has heated up rear window, as I can't remember which of the two it does normally???
