How to remove R33 GTS wing
  • How to remove R33 GTS wing
    Just so I don't break the thing, can someone tell me how many bolts hold the R33 GTS25T series 1 wing on the trunk lid? I can see two per side, but it feels like there are more holding it on.
    '93 R33 Gts25T Inked Art Car - SOLD
    at www.inkedartcars.com
    From 'papalazarou ' on Skylineowners.com:
    firstly remove the boot lid protection cloth piece,if your lucky enough to have one,apparently a rarity..this is held on by round plastic buttons,dont try to pull the cover off and pop these off,it wont work,you have to get a flat screwdriver behind the cover and press in one side of the button stems,they will then easily pop out.once removed you will see all access points to the four nuts(2 each side).2 hidden by rubber grommets,and one hidden by the light block.undo these four nuts.then shut the boot,and carefully with preferably a flat wooden object,i used a ruler,lift up the 2 front blades,these then pop out the clip blocks.then give the whole spoiler a tap forwards towards the rear window,as there are 2 slide pegs on the rear,one on each corner,put your fist between the boot and the spoiler top arch,and carefully turn your hand,and the width will gradually slowly raise the spoiler,and pop it off the boot.should be off now.
    Full thread here: rear gts spoiler removal. - Skyline Owners Forum
