i have been having issues with my headlights, the passenger lowbeam use to work tell i was in an accident 2 years ago, worked fine tell about a year then it would flicker off and on if you moved the harness, now it wont work at all. traced all the wires to the fuse box, the grounds are all good but after the rad by the battery i have traced the yellow/red to that far and have no clue were to go from there, all the way to there, there is no splces, there is power to the light i checked with my test light, also if i put my highbeams on the light doesnt work, but if i flickthe highbeam(pull towards) thehightbeam will flash. i have replaced the signal switch, what else is left to check? any wiring diagram?
headlight
