To start, I did do a search for each of these questions but they either lead me to threads where one thing was solved and another wasn't, or the threads were never replied to with a satisfactory answer.
First the idle problem: The car is fine when cold, but as it warms up it starts to idle really low (400-500rpm) and when rolling to a stop it has a tendency to drop REALLY low (200-300) and sometimes die completely. After reading multiple threads the three major ideas that I came up with are: Maf/TPS/Battery. My battery is a new optima red top but HAS been jumped 4 times since I've owned it (Usually from leaving lights on in the morning when getting to work.) So I've all but eliminated that, if someone thinks that really might have killed it then I guess I need to search for a new battery.
#1 Would it be possible to put a Z32 maf on RB20DET with a socketed ECU and only need a minor tune? I'm looking to fix my idle problem as opposed to making power atm. The reason I want a different maf on to fix the idle is I figure I will upgrade the maf sooner or later (other mods kind of ask for it) and I figure if it's cost-friendly I should just do this if it will fix my problem also.
#2 Is nistune 'nooby friendly' I'm not very mechanically inclined but would I have to have someone dyno tune for the simplest things, or is it as simple as clickclick done? (ala z32 maf) I would obviously have someone experienced install nistune for me.
#3 I can't seem to get a reading of voltage on my TPS. I tried to do it where the white middle wire is and the volt meter doesn't show anything. Sits at 0. I tested it on the battery and the volt meter works fine so I'm not sure what the problem here is? A lot of threads mention the TPS as the culprit for a bouncing or low idle but would the car work AT ALL if it was completely dead? I unplugged the side part for a short 15 second drive and my RPMs sat at 1.9k, so I assumed if it was actually dead it would do something like that?
#4 I have a walbro 255lph pump in my car, second one in under 6 months. The first one apparently died, or was close to according to the techs at racing greed. When I replaced it my cold start problem went away but the idle problem stayed (had hoped it would fix it) I was wondering if I should be putting an aftermarket FPR in to help with this?
List of mods on car:
Exoticspeed FMIC (don't remember size, if it's truly important I can look it up
Deatchwerks 444cc injectors
Walbro 255lph
3" exhaust
K&N air intake cone; assuming it replaced the OEM one? Sensor cone is attached to looks stock but again I have nfi what I'm talking about!
socketed ECU - tune done by techs at ztune
manual boost controller set to 14.5psi
yellow jacket coils, put on 12k km ago.
I think that's everything?
Any help in this matter would be greatly appreciated. This problem has been very persistent (couple months now) and I would really like to get rid of it and start enjoying my car again.
Also if anyone has a spare stock rb20 maf that they wouldn't mind lending me for a day or two I'd be greatly appreciative. I could then test if that is the problem and try and save myself some money in eliminating problems.
Sorry for the huge text bomb and beating a dead horse with questions that I know have been asked before, but again like I said either the answers weren't straight forward enough (I'm dumb.) or I'm dumb.
Thanks!
Walbro 255lph
3" exhaust
Thanks!
