JohnZ32, just takes fitting exhaust to upset tune on factory ECU startup tables. Drycell battery is worth the $$$. Can save up to 14kg (depends on brand of battery), get better cold starts. Normal battery weighs something like 20kg. Get a slight performance gain (power to weight) for not much $$$.
I think that servo / flap thing is what I'm talking about. It was partly set to hot on my car, so wasn't cooling enough when set too lowest setting on aircon control. I've heard of them getting stuck, etc and need lubing, fixing, etc.
On R32, powersteering rack in front and HICAS rack in rear use the same powersteering pump (HICAS uses rear of powersteering pump) in engine bay and has a solenoid next to battery that directs fluid to rear of car to turn rear wheels. From what I understand, this solenoid is the cause of heavy steering, as HICAS ECU controls this solenoid. So if HICAS ECU plays up, so does solenoid. At least, that's how I understand it. Also there's another solenoid at rear of car, near rear wheels.
On R33 the rear and front are separate systems. Rear HICAS rack is electric driven, front rack runs off powersteering pump. It's common to use R33 pump or non HICAS R32 GTS pump when removing HICAS properly.
