RB25 PonCam Install
  • RB25 PonCam Install
    Hey guys, never found a for sure answer. When installing drop in tomei PonCams in an rb25 s1 do you have to drain the lifters or are they literally just bolt in and go?
    Thanks Brian
    no u dont have too
      awesome, thanks, could not find tomei base circle dimension and no one says you have to do it on any how to forum.
        Ya, it's literally that simple.. However even pulling the head and affiliated parts like the buckets and what not.. the hydraulic lifter system will refill once the pump begins to muster up pressure..
        You kind of deal with it on a daily basis; when you dont run the car for extended periods of time, you hear what seems to be a lot of valve slap; just your lifters building up oil pressure.
        www.nelsonmx.wordpress.com
          perfect, Ya i could not find a definite yes or no. That helps lots thanks guys
            You're meant to fit new lifters (applies to hydraulic, solid lifter) with new cams, as lifters are bedded-in with each lobe on cam and the old lifters were bedded-in with stock cams. Also fit new valve springs. Then do the break in procedure. That's if you want valvetrain to be reliable.
            I agree with that slap sound when engine hasn't been running for a while. I crank engine longer and seems to solve that problem.
              You're meant to fit new lifters (applies to hydraulic, solid lifter) with new cams, as lifters are bedded-in with each lobe on cam and the old lifters were bedded-in with stock cams. Also fit new valve springs. Then do the break in procedure. That's if you want drivetrain to be reliable.
              Right, good point. It's safe to re-use lifters as long as you replace the buckets in their appropriate position, that way any wear amongst the shims is uniform and not displaced after reinstallation. However in your case Brian, you wont need to as you're not removing the buckets. I agree though, changing all these and doing the proper break in is a GREAT way to prolong the life of your valvetrain.. I plan to do that with my new springs/cams/valves etc.
                From what I understand, more aggressive cams shorten lifespan of valvetrain components, so replacing with new parts becomes more important.
                I think with Poncams, they are not aggressive enough to affect lifter, valve springs, etc. From what I can remember, Tomei mention this about Poncams on their website. They are similar to regrounded stock cams that drop in, but new blanks are better for longevity.
                Can understand why Tomei use new blanks -
                Also why was I thinking of drivetrain?, meh, shrug.
                  ya the upgrade i was thinking was the standard 8.5 mil 256 duration cam. Nothing crazy just a bit better than stock. Having said that any opinions on who is the best to buy them from? Best price, service etc?
