Hub bolt , need help
  • Hub bolt , need help
    Hi
    I'm looking to buy new hub bolt for my r32 gts-t , I would like to know witch usdm nissan hub bolt fits on gts-t for front and rear hubs
    thank you
    Hay guys, i changed my wheel studs today. i didnt realise that it would be so easy. i went to a few shops and they wanted about 60 dollars a stud to change over for me so basically i thought that was a jok so i will write step by step how to do it it took me about 20 mins each wheel to change the...
    Regards,
    Ken.
      ARP makes replacement wheel studs.
        rear hubs are same as 240sx S13 89-94. just snag one from a junk yard for like a dollar if lordco or such doesn't carry em for a reasonable price.
        Front's not sure, but potentially 300zx???? maybe someone else can chime in on the fronts. but rears are def same as s13
        edit:
        oops pretty sure i read that wrong. are you looking for wheel studs? or the big nut that holds the axle in the hub?
        wheel studs are same as s13. though most nissans all use the same wheel studs metric 12mm x 1.25pitch.
          Thank you , yes I' looking for wheel studs
