240sx HICAS Lockout On A R32
^ I second that. If you go to any website I will show you that the hicas bars are compatible. But once you start using other components like coilovers s13=32 gts, 300zx tt = gtr from my knowledge anyways. If I'm wrong please do chyme in!Miss driving sooooo bad! Need to get a car on the road ASAP!
s13 rear subframe is same as gts-t i can vouch, as i'm running s13 knuckles, subframe, gts-t hubs and brakes and diff and axel shafts had gts-t rucas and everything lines up perfectly. so common sense would say the lockout bar has too be 100% compatable
Yes it is compatible. The s13 and r32 gts rear subframe is exactly the same. thats why its common for people to find a non-hicas s13 subframe and swap it into the skyline.
All the rear suspension components are the same too Hicas to hicas and Non-hicas to Non-Hicas. The only part that isn't interchangeable is the Rear toe rod and thats only if your going from Hicas to non-hicas, or vice versasigpic
Originally posted by m_melen...it woulda been safer if his harness were made of jello
GTS, GTR should be the same.
I have the same type of lockbar on my car. Only problem is your still using the factory balljoints which are a pain to remove from hub due to grease nipple, etc when they fail.
If had to do it again, this is what I would fit (or similar kit from Japan) -
Fitting the above kit -
It removes the balljoints and easier to replace parts.RESPONSE MONSTER
You're welcome.
There is a aftermarket balljoint, probably $30 CAD. Factory balljoint is not lubed at factory and has to be luded via nipple. Aftermarket balljoint is prelubed. Don't know the brand of balljoint.Last edited by Skym; 03-26-2011, 04:07 AM.RESPONSE MONSTER
When I did my lock bar. I bought the lubed ball joints from z-tune when they were open. And to get them out I used a pitman arm pulled from c-tire and a large nut on the back side and they came out no problem. To get them back in use a socket that is just wide enough to catch edge or make your own to fit. Worked great.
But if I had the money and time to do it what skym said I would definitely recommend that!!
Good point. Probably why factory used balljoints. One thing I noticed with movement in one of those arms (factory) is you can feel the wheel break traction on that side when cornering and noticed excessive tyre wear.
This is version of the same HICAS eliminator kit from Japan (maybe the kits in Japan are better???) -
Maybe they use hardened rubber bushes or similar???
Also I would worry about not greasing the rod, etc properly, as from experience if metal of arm to metal rod part of poly bush locks, can rip poly bush apart. Did it on top arms on front of my car.Last edited by Skym; 03-27-2011, 03:11 AM.RESPONSE MONSTER
