My heat only stays warm, never goes hot or cold.
Also it take a long time for my car to get up to temp, and I have changed my stat aswell already.
I did a climate control test on my GTS-4 and it came back like this, code 24 & 25
Then I did a temp test sensor read out and the temps read like this with the outside air being -2.
-3, 5, -30 & 5 were the read outs
The code are pointing at suction temp, (I think)
I looked for DIY on this and there only info on how to scan the unit, so if there some members here that can help me pin-point my problem that would be awesome.
Its no hurry because I am gutting the car to remove all the floor tar and extra weight that I can, then doing my engine build after I restore the best I can.
So I want my electrical system and cooling system to work correctly before I go adding new problems, thanks in advance.
