Hey everyone,
So first off.. i need to start my skyline to move it away from the garage wall so i can start to work on my wheel and suspension mods. Its about 8 inches from the wall (i needed the garage space at the time).
I was a dumbass and didn't put any oil/fuel stabilizer before parking it
It has not been started for 5 months. The car will crank but it will not turn over. So these are the things I've tried so far..
- Added 10 L of fresh premium gas
- Added a dose of winter fuel injector cleaner (should prevent gas lines from freezing)
- Bought a brand new battery (570 cold crank amps, 680 amps)
- Magnetic oil pan heater running for 2 days already
- Checked fuel pump fuse.. its good. Fuel pump whines on pre-ignition
- Took off Apexi air filter cone and sprayed Quick Start® through intake
- Hooked up a booster pack to the battery terminals to give it more OOMF
It will crank and I could rear it begin to start for a split second at a time and the tach needle would jump a little. It wants to start but it won't.
As a side note, the weather here in Winnipeg has also been hitting -28 lows and -40 with the wind chill.
Please offer me some advice guys. I know you are a knowledgeable group!
Thank You!
Thank You!
